N-gear problem in Chrysler Grand Voyager
I have probelm with my Grand Voyager LE 3,3 V6 engine (1996) with automatic transmission. When gear is in N-position and car is in the move (backward or forward) it breaks like gear would be on. All the other gears work like dream appart from N-position.
I have tried to find out the problem by disconnecting the 8-pin power cable that goes to the gearbox solenoid. When the cable is disconnected gearbox finds the N-position, but when cable is connected it does not. The TCM has been changed to new, but it did not solve the problem. At the gearbox there is no neutral "start/back up" -switch at all. Inside from the gearbox the 3rd and 4th gearwheels has been chaged in garage as they were a bit broken. Does anyone know the PRNDL-switch, in which colour is the cable that is for N-gear and where does it go to? |
Originally Posted by hattumies
(Post 30797)
I have tried to find out the problem by disconnecting the 8-pin power cable that goes to the gearbox solenoid. When the cable is disconnected gearbox finds the N-position, but when cable is connected it does not. The TCM has been changed to new, but it did not solve the problem. At the gearbox there is no neutral "start/back up" -switch at all. Inside from the gearbox the 3rd and 4th gearwheels has been chaged in garage as they were a bit broken. Does anyone know the PRNDL-switch, in which colour is the cable that is for N-gear and where does it go to? If I got your gearbox in my shop, I would verify your complaint (I've never heard of what you are describing) and I would use pressure gauge to see if there's some cross leaking causing unwanted apply. Just speculating, I'm wondering if there's a problem with the manual control valve. |
