N-gear problem in Chrysler Grand Voyager
Old Sep 25, 2009 | 12:11 PM
hattumies's Avatar
Unhappy N-gear problem in Chrysler Grand Voyager
I have probelm with my Grand Voyager LE 3,3 V6 engine (1996) with automatic transmission. When gear is in N-position and car is in the move (backward or forward) it breaks like gear would be on. All the other gears work like dream appart from N-position.
I have tried to find out the problem by disconnecting the 8-pin power cable that goes to the gearbox solenoid. When the cable is disconnected gearbox finds the N-position, but when cable is connected it does not. The TCM has been changed to new, but it did not solve the problem. At the gearbox there is no neutral "start/back up" -switch at all.
Inside from the gearbox the 3rd and 4th gearwheels has been chaged in garage as they were a bit broken.
Does anyone know the PRNDL-switch, in which colour is the cable that is for N-gear and where does it go to?
Old Sep 25, 2009 | 01:19 PM
22chrysler's Avatar
This does not sound like an electrical issue.
If I got your gearbox in my shop, I would verify your complaint (I've never heard of what you are describing) and I would use pressure gauge to see if there's some cross leaking causing unwanted apply.
Just speculating, I'm wondering if there's a problem with the manual control valve.
giwan
Nov 15, 2011 05:07 PM
rickie_doo
Jul 8, 2011 03:45 AM
auto_geo
Apr 8, 2011 11:49 PM
bradleigh1977
Mar 17, 2011 12:29 PM
leepy
Sep 22, 2009 02:30 AM
