no spark at plugs
Old Oct 21, 2008 | 11:47 AM
rsg1972's Avatar
Default no spark at plugs
hi there i have been given a chrysler voyager 3.3 v6 just put a new head on as the old one had dropped a valve. all put back together correctly, but have no spark at plugs from coil. i have changed the crankshaft sensor and coil is there anything else i need to check. does the fact i havent got the code for the stereo play a big part in the immobilser side of it as when i use the key less entry , it spins over a treat, but wont start. please help as my wife is moaning at me to get it sorted as we are spending money and it still wont go. thanks ray
Old Oct 22, 2008 | 01:25 AM
I wonder's Avatar
Default RE: no spark at plugs
Hi
you got the wires wrong.
you MUST have ground on one of the terminals of the DIS system (you call it the coil I believe), you MUST have a positive on the other terminal.
and that's it.
if you're not sure, have an electrician to look at it.
if that's OK, then it has to be a computer that's taking care of the ignition, but I don't believe that's the case here.
Old Oct 23, 2008 | 05:35 AM
rsg1972's Avatar
thanks for your reply, do you have any wiring diagrams of this as im no wizard when it comes to this, please could you give me any indication as to which one should be ground and which one is positive. thanks ray
Old Oct 24, 2008 | 01:55 AM
I wonder's Avatar
sorry
autodata that I have does not have that year/model.
but, as a rule of a thumb, there should be only two connectors on DIS.
with the ignition on ACC, it should show positive on one and negative on the other.
if you can't figure it out on your own, have an electrician to look at it. you can easily blow the computer by shorting two wrong terminals.
WillQRose
Oct 18, 2018 07:18 PM
austin
Cirrus & Breeze
Sep 16, 2012 09:09 PM
Mykonoskid
Apr 21, 2007 10:42 AM
boss dog
Feb 9, 2006 01:13 PM
300Cno1
Sep 4, 2005 05:06 PM
