Noise at engine shut down
Old Apr 19, 2007 | 11:18 PM
F150's Avatar
Default Noise at engine shut down
My 2001 Town & Country with the 3.8 makes a grinding noise when I turn the ignition off. It only lasts for a few seconds and sounds like it's coming from the engine compartment. The oil and all other fluids are good. Thanks in advance
Old Apr 20, 2007 | 01:06 AM
Default RE: Noise at engine shut down
that helps out none more detail
Old Apr 22, 2007 | 11:55 AM
F150's Avatar
The best I can discribe it is it sounds like a cat growling. It only happens at engine shut off. Could it be the electric fans ?
Old Apr 22, 2007 | 01:47 PM
they dont run all the time only when engine temp is above 215 and then only untill the temp goes down then shuts them off. Does it do it or not with the ac running?
Old Apr 22, 2007 | 02:12 PM
F150's Avatar
It does it with or without the A/C on. The noise is not present at start up or when the engine is running.
Old Apr 22, 2007 | 08:24 PM
hummm could be something in teh fan area then have some on sgut off the van and have a look
Old Apr 29, 2007 | 02:36 AM
F150's Avatar
The noise was being caused by the clutch in the alternator.
Old Sep 10, 2007 | 08:19 PM
tdcobb7's Avatar
Was it also making a squeeling noise when you started it up during the winter? I think mine is doing the same thing.
Thanks,
David
Old Nov 26, 2007 | 07:07 PM
jquinones's Avatar
happen to my van too!! same noise when I turn off
did you find what it was?
thanks
Old Nov 27, 2007 | 05:46 AM
F150's Avatar
ORIGINAL: F150
