oil change
I have a 2009 town country. I have changed the oil how do I get the message off where the odometer is located? Thanks
David |
From the owners manual:
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Menu button. To reset the oil change indicator system (after performing the scheduled maintenance) perform the following steps. 1. Turn the ignition switch to the ON position (do not start the engine). 2. Fully depress the accelerator pedal, slowly, three times within 10 seconds. 3. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illuminates when you start the engine, the oil change indicator system did not reset. If necessary, repeat these steps. George |
Just what I needed to know. Thanks again
David |
I've performed this procedure five times, each time ensuring it was completed within ten seconds, though not less than eight seconds. However, the message doesn't reset.
The van is a 2014 T&C Touring L with a Braunability wheelchair conversion, if that makes any difference. Any suggestions would be appreciated, thanks. |
Originally Posted by hytec
(Post 98935)
The van is a 2014 T&C Touring L with a Braunability wheelchair conversion, if that makes any difference. Any suggestions would be appreciated, thanks. If you'd like to PM your VIN, I can check to see if there's something else we can do to help you reset the message. Kori Chrysler Social Care Specialist |
Kori, I PM'd the VIN Saturday as you asked. Have you been able to determine anything that may help solve this issue? Thanks, Hank
(Post 98997)
Kori, the proper procedure worked fine.
The problem was with me. I didn't realize the ignition was a two-position switch, ACC and RUN. Placing the switch in the RUN position cleared the message the first time. As has been said many times: "Too Soon Old, Too Late Smart." <gr> Thanks, Hank |
(Post 99013)
...The problem was with me. I didn't realize the ignition was a two-position switch, ACC and RUN. Placing the switch in the RUN position cleared the message the first time...
