oil change
Old Dec 27, 2014 | 03:33 PM
davidgossett's Avatar
Default oil change
I have a 2009 town country. I have changed the oil how do I get the message off where the odometer is located? Thanks
David
Old Dec 27, 2014 | 06:25 PM
georgef's Avatar
From the owners manual:
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Menu button. To reset the oil change indicator system (after performing the scheduled maintenance) perform the following steps.
1. Turn the ignition switch to the ON position (do not start the engine).
2. Fully depress the accelerator pedal, slowly, three times within 10 seconds.
3. Turn the ignition switch to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you start the engine, the oil change indicator system did not reset. If necessary, repeat these steps.
If you don't have an owners manual you can download one here: http://www.dodge.com/en/owners/manuals/
George
Old Dec 27, 2014 | 08:14 PM
Just what I needed to know. Thanks again
David
Old Jan 20, 2017 | 12:07 PM
hytec's Avatar
I've performed this procedure five times, each time ensuring it was completed within ten seconds, though not less than eight seconds. However, the message doesn't reset.
The van is a 2014 T&C Touring L with a Braunability wheelchair conversion, if that makes any difference. Any suggestions would be appreciated, thanks.
Old Jan 20, 2017 | 04:52 PM
ChryslerCares's Avatar
Hi hytec,
If you'd like to PM your VIN, I can check to see if there's something else we can do to help you reset the message.
Kori
Chrysler Social Care Specialist
Old Jan 24, 2017 | 07:17 AM
hytec's Avatar
Kori, I PM'd the VIN Saturday as you asked. Have you been able to determine anything that may help solve this issue? Thanks, Hank
Old Jan 24, 2017 | 08:53 AM
Hi Hank, I responded to your message a short time ago, I apologize for the delay.
Kori
Old Jan 25, 2017 | 03:32 PM
hytec's Avatar
Kori, the proper procedure worked fine.
The problem was with me. I didn't realize the ignition was a two-position switch, ACC and RUN. Placing the switch in the RUN position cleared the message the first time.
As has been said many times: "Too Soon Old, Too Late Smart." <gr>
Thanks, Hank
Old Jan 25, 2017 | 03:46 PM
georgef's Avatar
...The problem was with me. I didn't realize the ignition was a two-position switch, ACC and RUN. Placing the switch in the RUN position cleared the message the first time...
Thanks for the update, it could help someone else making the same mistake.
15951a\
Nov 24, 2021 06:40 PM
Nick1981-1
Aug 19, 2013 05:27 PM
flaxman
Sep 5, 2011 02:10 AM
popymoose
Nov 12, 2007 04:58 PM
2006 300C
Feb 26, 2006 12:44 PM
