Oil, Water problem
Hi everyone, I've just bought myself a 2004 Grand Voyager 2.8 CRD LTD XS and i love it, it has a few minor probs with it that i can fix as and when i get time, but there is 1 problem i have found that is worrying me a bit
I have found oil in the cooling system expansion tank, i have searched the site and think it is the oil cooler which can be bypassed temporarily, i'm just after a bit of clarification really, could it be another problem or is this likely to be the only reason oil would be in the water, and where is the oil cooler situated.
TIA
TIA
I'm afraid the Head gasket is a fairly big job. Depends on weather or not you choose to replace the timing belt while you're at it (it has to come off to get the cylinder head off) and if the head needs skimmed, but you'd have to budget maybe £500 minimum at an independent and maybe £1000 or more at the dealer.
By the way, how many miles has it done?
cheers for info booke, it has done 142,000 mls.
I've just bypassed the oil cooler and flushed the cooling system gonna see how it goes for a couple of weeks, obviously there will still be oil residue in cooling system but a few flushes should get rid
Hopefully that'll be whats causing it. Certainly best to rule out the oil cooler before you start stripping the engine.
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
musicfreak2195
Jul 7, 2009 02:23 PM
