ongoing problem HELP!!!
Old Oct 16, 2010 | 12:18 PM
voyager_dan's Avatar
Default ongoing problem HELP!!!
hi i have a 1998 voyager 2.5td ,the problem i have is that it randomly cuts out the glow plug light flashes ,switch off ignition then it will start first time and maybe ok for the rest of the day or weeks or it may do it a couple of times the same day,seems to do it when slowing down like today my wife was stopping at some traffic lights it cut out and has been fine for the rest of the day
i have changed the crank sensor it has been just over week since changing the sensor,also have pulled on the loom with it running couldnt get it to faulter
iam a bit reluctant to have it plugged in at chrysler for them not to find a fault ,i have tried the dash menu but no stored codes and have had it plugged into a solus scanner again no fault stored
thanks for reading
dan
Old Oct 17, 2010 | 04:08 PM
it did cut out again last night,today it has been fine
i have been through a couple of earthing points and cleaned up,checked plugs and the loom
if i dont get this sorted it will be going to the crusher before it kills me or the wife
found a few other posts on other sites where the same problem has occured but no one has got a solution
Old Oct 24, 2010 | 03:10 PM
been to chrysler plugged in and................needle movement sensor...............PUMP!!!!!!!! oh dear gonna cost £650 to have pump re-worked maybe a voyager bonfire on nov 5th,be a real shame to damage those 300c wheels!!!
Old Oct 26, 2010 | 12:40 PM
oops got it wrong its the fuel quantity actuator,needle movement sensor is in the #1 injector
big bonfire coming up should burn well!!!!!!!
Old Nov 1, 2010 | 02:37 PM
i had the fuel actuator adjusted today ,seems to run a bit better bit more power probably down to putting the fuel up a bit ,will see if this cures it......or not!!!
the guy at the diesel place i took it to was really good ,he suggested trying this before a new actuator is ordered
(these can be changed in-situe how many diesel places will tell you that!!!!!!)
possibly a pump rebuild but he thinks the pump appears ok
Old Nov 2, 2010 | 05:06 AM
baggins's Avatar
well I hope things work out ok and glad to hear the bonfire is off for now
Keep us informed of the outcome and thanks for sharing your experience, lets hope for a happy ending .
Old Nov 3, 2010 | 05:46 PM
lets hope so ,it goes a bit better now too
Old Nov 7, 2010 | 05:11 PM
been a week and 1 day since the last cut out happened ,was doing it every coulpe of days before the actuator adjustment......fingers crossed!!!
Old Nov 11, 2010 | 06:36 PM
1 week 5 days !!!!!!! ..................keep touching that wood!!!!!!!!
Old Nov 17, 2010 | 01:57 PM
2 weeks 4 days ..........looking promising!!!!!!!
