Only tach not working 2005 T&C
Dead Tachometer.
No codes showing. Every thing else is nominal. Few days back I noticed the ODO and shift lever indicator at the bottom of the inst cluster were flickering slightly. Yesterday morning it stuck the key in ignition, turned it to crank position - NADA - DEAD. Pulled it out with a few choice words. :mad: Stick it back in and it cranked and started just fine.... :) ? ? ? ? The tachometer is deadern' a door nail 3 days now. Every thing else is steady and nominal. Suggestions? |
sorry -addendum - needle position
The tach needle is wound hard up against the peg -as if the engine was turning 'bout 14,00 rpm!
press the trip reset and hold put key in ign and turn the key to on POS then after a few seconds the cluster should go into a self diog mode and will sweep all the needles around back to correct way.
Thanks for the timely reply.
Will try that this AM as I go out to get some meds for some grandkids with bad colds. Pete Peterson |
Worked thank you.
And with the word reset in my search(s) I discovered a whole host of info in the forum. That was my lack - the effective term required -that I didn't have for the context. |
welcome
