Only tach not working 2005 T&C
Old Nov 25, 2013 | 12:20 PM
Pete Peterson's Avatar
Default Only tach not working 2005 T&C
Dead Tachometer.
No codes showing.
Every thing else is nominal.
Few days back I noticed the ODO and shift lever indicator at the bottom of the inst cluster were flickering slightly.
Yesterday morning it stuck the key in ignition, turned it to crank position - NADA - DEAD. Pulled it out with a few choice words.
Stick it back in and it cranked and started just fine....
The tachometer is deadern' a door nail 3 days now.
Every thing else is steady and nominal.
Suggestions?
Old Nov 25, 2013 | 01:05 PM
Default sorry -addendum - needle position
The tach needle is wound hard up against the peg -as if the engine was turning 'bout 14,00 rpm!
Old Nov 25, 2013 | 04:15 PM
press the trip reset and hold put key in ign and turn the key to on POS then after a few seconds the cluster should go into a self diog mode and will sweep all the needles around back to correct way.
Old Nov 26, 2013 | 10:26 AM
Thanks for the timely reply.
Will try that this AM as I go out to get some meds for some grandkids with bad colds.
Pete Peterson
Old Nov 27, 2013 | 03:13 PM
Worked thank you.
And with the word reset in my search(s) I discovered a whole host of info in the forum. That was my lack - the effective term required -that I didn't have for the context.
Old Nov 27, 2013 | 09:03 PM
welcome
carsoftampabay
Cirrus & Breeze
Oct 26, 2012 11:31 PM
MarkOb
Nov 12, 2010 11:03 AM
KMusTeach
Apr 9, 2008 02:55 PM
jessestaton
Dec 27, 2007 10:29 AM
timejerker69@yahoo.c
Aug 14, 2006 11:39 PM
