P0456 Small Evap Leak 2001 T&C LXi FWD 3.8
Old Oct 5, 2012 | 02:52 PM
Gonorm's Avatar
Default P0456 Small Evap Leak 2001 T&C LXi FWD 3.8
My 2001 T&C LXi FWD 3.8 shows a P0456 code Small Evap Leak.
I did a visual inspection of gas cap, under air box hose, under car hoses, pulled vacuum on vent valve, looking at typical trouble spots based on internet search for similar problem. I did not find a problem.
I reset the code by disconnecting neg battery cable. The P0456 reappeared after few minutes driving.
I took it to a local shop. They came back saying I needed a new Leak Detection Pump. Said they found no leaks so they disconnected LDP did a check and determined LDP bad. Details of check not clear.
I hesitated because I thought there were two checks run by the system on the LDP itself that would have to pass before the system would run the Evap leak test and throw a P0456.
Question to you guys. Can the LDP cause a P0456? If this doesn't make sense then what would you suggest?
Thanks.
DKats
Jun 17, 2024 04:21 PM
a_kraker99
May 8, 2021 09:48 AM
snowbird2006
Dec 1, 2014 01:01 PM
Sarape
Oct 26, 2011 01:13 PM
onemadmech
Aug 13, 2007 06:29 AM
