Small evap leak
Old Jul 28, 2007 | 02:28 PM
onemadmech's Avatar
Default Small evap leak
I have a 2003 with a 3.3 sets code for small evap . Checked hose at canister. Couldn't find any cracks.
Checked the purge solenoid dosen't hold vaccum lose 1 to 2 inch of vaccum in about 20 sec. than holds
Any help
Old Jul 29, 2007 | 12:37 AM
Default RE: Small evap leak
under the body hoses crack as well .
Old Aug 11, 2007 | 08:52 AM
Lifttech's Avatar
I'm not sure if the intake/throttle body config. is the same as my 3.8 but you might check the small vacuum elbow below the throttle body. It should connect to a nipple on the TB and to the plastic vac lines. Helps to remove the air filter for this and it would give you a chance to check the rest in that area. HTH
Old Aug 13, 2007 | 06:29 AM
davet's Avatar
A friend had the same thing on his Dakota. I checked all the Evap hoses under the hood and found the problem. One of the hoses from the canister had a couplingin it about 3 feet from the canister where it mated to a preformed hosethat continued under the firewall. At that coupling the hose was cracked on the underside. I cut 3/4" off and reattached it and problem solved.He had been to 2 different shops and each gave him a different reason for the leak and quoted much money to fix.
a_kraker99
May 8, 2021 09:48 AM
snowbird2006
Dec 1, 2014 01:01 PM
rocksockdoc
Oct 17, 2013 11:12 AM
Gonorm
Oct 5, 2012 02:52 PM
VFRbeliever
Cirrus & Breeze
Oct 29, 2007 11:55 AM
