alexyoung59 |
10-20-2011 07:44 PM |
Power Steering Gives out momentarily
My 01 T&C will sometimes lose MOST, not all, of the power steering when making slow speed harder turns and when completely stopped and turning the wheel (like after backing out of a spot and turning the wheels). I am pretty sure it's not losing all the power because you can still turn it, just takes a good bit more effort (as compared to no effort when its working right). I have not noticed ever doing this when making very slight turns, like switching lanes on a highway, nor when going over 15 to 20 mph and making a turn. I have read on numerous sites that there was a TSB on these vans for a power steering hose that was too small. Is this on of the symptoms associated with that TSB and the small hose, or could it be that my power steering pump is going out. Or worse, could my rack and pinion be going. The car leaks no power steering fluid whatsoever. Have driven it at least 1500 miles and the fluid is full and I have spotted no leaks when going under the car for other work.
