problem with 2003 t/c
my wife has a 2003 town and country and a few days ago she went to start it and it wouldnt start.it turns over but it wont start.it sounds weird like when you turn the key to start it,it turns over faster then usual but wont start.i did the "key dance" and check to see if there are any codes and i got 2 (p1684) and (p1388).
thank you for youre help |
P1388-auto shutdown relay control circuit
possible causes asd relay operation fused b+ output circuit asd relay ipm fuse & relay center (k51) asd relay control circuit open (k51) asd relay control circuit short to ground pcm |
P1684....Battery disconnected during last 50 starts
Not a lot of help but don't think thats as important as the other error code |
thanks guys,i will check the fuse box and see what i can find.
thats for the p1388 and about the p1684,i did took the batery posts off to clean them a few days before this happen.thank you |
dont worry about 1684 it means nothing
I went to start it just to see if it would start,and it did.it started for a few seconds than it died again.is there a way totest the ignition coil to see if its working correctly.or any ideas on what it could be the problem .thank you
U already know your issue is with the ASD relay circuits that is where u need to concentrate
thank you.i swaped the ASD relay in the fuse box with another one in the box,just swaped them around but it didnt do any good.
its not an asd relay issue
it is gonna be a wire issue or a pcm issue |
well,i went to see if i had spark but there is no spark on any spark plug wire.could it be the computer that went bad.is there a test that maybe could tell you that it did go bad.thank you:confused:
