question
Old Sep 10, 2014 | 10:14 AM
rekline's Avatar
Default question
on a 1998 Town and Country. Is there a module or relay that would keep it from running at certain times. Sometimes it will start and die three or four times, then nothing.
Old Sep 10, 2014 | 03:21 PM
You'll need to identify your car more clearly...And describe the symptoms more clearly like cuts out under acceleration, problem starting, etc...
Old Sep 10, 2014 | 05:47 PM
- if yours was a 2004 + I'd say its SKIM / SKREEM immobilizer module protection
- if yours was a 1998 + I'd say its immobilizer module protection
- do you have a flashing or other light that indicates a fault in the immobilizer system ?
Old Sep 11, 2014 | 07:55 PM
rekline's Avatar
It will start, die three or four times. Then there is no clicking or anything. The next morning, it starts and runs fine. Not an all the time thing.
Old Sep 11, 2014 | 10:18 PM
is teh cluster dead at the time when it wont start teh 3-4 times?
Old Oct 10, 2014 | 08:00 PM
rekline's Avatar
1998 Town and Country with the 3. something flex fuel engine. Intermittently starts and dies several times, then nothing. The next day, it starts and runs fine. The cluster doesn't light up. Could it be the immobilizer module protection and how do I get it fixed?
Old Oct 11, 2014 | 12:04 AM
none of the stuff on the cluster works when it wont start?
Old Oct 11, 2014 | 05:07 AM
rekline's Avatar
No. And there is no clicking or anything when the key is turned. I'm about ready to junk it!
Old Oct 11, 2014 | 02:34 PM
sundowners's Avatar
I am just guessing---but---- could it be something simple??? like a loose/bad connection ---battery lead etc. ????
Nigel
Old Oct 11, 2014 | 06:58 PM
bang the top of the cluster see if it will wake the cluster up its more then likely bad solder joints on the cluster it will kill the commutation and not allow things to talk to each other.
