Questions about rear A/C & fan
Old Jul 22, 2011 | 12:01 PM
HuskerChrysler's Avatar
Default Questions about rear A/C & fan
Hi folks. First time poster here so forgive me if I breach any rules or anything!
Our 2006 T&C has developed a leak somewhere in or around the rear A/C evaporator. I've got some questions about it.
1. When the switch on the dash for the rear unit is turned to "fan" does that engage the rear a/c evaporator? Or does it only turn on when I turn the fan to the right position(s)?
2. My mechanic tells me it could be as much as $900 to replace that rear a/c evaporator. And it could stil be several hundred or more just to fix the line(s) if that is where the leak is. Sound right?
Thanks in advance.
Old Jul 22, 2011 | 02:04 PM
the evaporator is a non moving part it has freon that flows through it the same time the front does. The fan only moves the air across it and as for a leak it all depends on where it is at and what needs to be fixed or replaced.
Old Jul 25, 2011 | 08:50 AM
So what is the difference between the one left dial position that says "fan" and graduated positions to the right?
Thanks for your timely response too by the way!
Old Jul 25, 2011 | 10:18 AM
i have no idea what the question is even about lets start by telling us what the prob is not what some one has told u what u are experiencing.
Old Jul 26, 2011 | 09:58 PM
TNtech's Avatar
The first position is to give control of the rear HVAC to the control unit in the back.....or "ON" The rest of the positions are you overiding their control...low/medium/high.
starzz
May 13, 2011 09:56 PM
antonylord
Oct 22, 2009 06:05 AM
Techstrider
May 22, 2009 12:47 PM
colbertgang
Apr 26, 2009 09:30 PM
sumncguy
May 9, 2007 09:36 PM
