Rear door stuck
Hi, I'm trying to fix my friends 1999 town and country. The rear door/hatch stuck closed. Taking off the trim showed that the button would trigger the unlocking arm when switched but it still wouldn't open. Which part should i replace? The latch attatched too the door that locks into the rest of the car?
RE: Rear door stuck
stick your arm down the back of the rear hatch panel and pull up on the latch to open the trunk.
RE: Rear door stuck
alike tech said pull up on the handle link right here:> replace the lift gate latch you should be fine as long as your handle still works.moehttps://w05.dealerconnect.chrysler.c...S/80a3b189.gif
RE: Rear door stuck
Anyway to check the handle before i reinstall? Do you happen to have a part number for that liftgate latch? Thanks for the help!
RE: Rear door stuck
heres your part # for the latch.4675776, once you have the latch off double check your handle make sure the rod clip didn't pop off.if it did you may have found your problem.lube the latch up and reinstall the rod.moe
