rear fog lights
Old Mar 22, 2014 | 06:32 PM
sundowners's Avatar
Default rear fog lights
Hi
The rear fog lights on our GV have not worked since we have owned the car-------I have read that the towbar wiring causes problems because of the way the lights are wired ?????---I suspect the lights have been disconnected to solve this problem ???
I am thinking of fitting a new switch and wiring a separate new fog light so that I can wire it into the trailer socket------is this the easiest option ? or should I try to 'correct' the existing lights-----IF I get to the original switch, any idea which is the fog light wire ?????
Thanks for any suggestions
Nigel
Old Mar 25, 2014 | 11:11 AM
sundowners's Avatar
Thanks for your help again Richard ----I think we have the answer for the fog lights
Your checking the air bag light seems to have worked-------the light was out on the way home --------time will tell if it's a 'fix'
But the exhaust gave up and we sounded like a tractor ------The cat dropped off the down-pipe--- -as you know I was expecting that eventually----We have it booked in tomorrow for that.
Thanks again
Nigel & Pamala
Old Mar 26, 2014 | 10:52 AM
tfb's Avatar
tfb
no probs, nice to see you again.
Richard
sundowners
Aug 7, 2013 02:39 PM
Rodneystr
May 22, 2008 05:22 PM
wt.pm
Mar 5, 2008 05:14 PM
f6lover
Feb 25, 2007 10:55 PM
bryant16e
Dec 19, 2006 01:59 PM
