Rear View Camera
Old Feb 17, 2010 | 07:27 PM
data174's Avatar
Default Rear View Camera
Does anyone have any idea how to adjust the rear view camera on my 2009 T&C. It's out of focus. Dealer said thats the way they are.
Old Feb 17, 2010 | 11:06 PM
mrfixit454's Avatar
Maybe you should sit in a new one on the lot and see how clear it is. Maybe you need a new camera?
Old Sep 14, 2013 | 10:57 AM
franklyray's Avatar
Default Out of focus backup camera 2010 T&C
Dealer told me the same thing "that is the way they are." Can someone give me the part number for the replacement?
I don't want to put in a new aftermarket with new rear view mirror, etc. Just replace with a new camera.
Thanks.
Old Sep 14, 2013 | 05:09 PM
georgef's Avatar
The part number is 5026338AB, manufactures suggested retail price is $275.00, and that is the for camera only, no bracket. You can get it online for around $190.00 plus shipping.
George
Old Sep 15, 2013 | 06:12 AM
Default Out of Focus
There's not something missing here like a lens that's been knocked off.
Old Sep 15, 2013 | 07:00 AM
Leedsman's Avatar
As focussing cameras was something I did all day everyday at ADT., usually twisting the lens back and forth will focus it. In your case, focus on infinity. I never found any camera that didn't work this way. The problem could be that the lens is locked in position by a very small allen screw (may be called a hex. screw) to which getting hold of a suitable allen key could be a BIG prob.
Leedsman.
Old Sep 15, 2013 | 08:16 AM
doug45601's Avatar
As mentioned above, there is no adjustment avail and that's the way they are per the dealership service dept. I went round and round on this issue with a couple dealers who in fact reviewed other vehicles to show me they were also blurred. My KIA Sorento on the other hand has a very clear view!
Old Sep 15, 2013 | 08:55 AM
Leedsman's Avatar
Doug, please inspect camera carefully, I'm sure there will be a way of focussing the lens, even my ultra cheapo web cam can be adjusted by twisting the lens. (I paid £2:50 for it). Maybe you have a friend into cameras?
Leedsman.
Old Sep 15, 2013 | 02:59 PM
doug45601's Avatar
I carefully examined the camera lens and could not see any way of adjusting it. The camera if flush fit into its plastic mount. There is a small drain hole in the bottom of the plastic mount verified by a strong light and mirror. If there is any adjustment to the camera lens and suspect the camera has to be removed from its mount which would require removing the internal parts of the hatch for access. That is something I would not mess with personally. Also I believe the folks at the dealership would be able to to do it if they could.
Old Sep 16, 2013 | 03:57 AM
Leedsman's Avatar
Yes I think you have it Doug, the cam. would prob. have to be detatched from its mountings to get at the lens focussing arrangements.
Leedsman.
