Replacement antenna
Old Dec 7, 2011 | 01:03 PM
andykb's Avatar
Default Replacement antenna
Does anyone know an easy way to fit a replacement aerial antenna to the front right hand side wing of a '99 Grand Voyager as there are box sections inside the wing and it is impossible to get your hand up there. Relocating is not an option as it will leave me with a hole in the wing. It looks like the easiest way is to remove the wing to gain access but this seems a bit extreme. Any help appreciated.
Old Dec 7, 2011 | 11:33 PM
TNtech's Avatar
You should be able to find an aftermarket replacement. DO you just need the mast or the whole thing? If you take out the inner shield you should be able to get to it.
Old Dec 8, 2011 | 05:13 AM
andykb's Avatar
No, I need to replace the aerial as well as the antenna. I have removed the wheel arch shield but it is still impossible to gain access to the underside of the wing. Looks like I'll be taking the wing off, bolt the aerial mast on, feed the wire inside the cabin then reattach the wing. Are the wings easy to remove?
Old Dec 9, 2011 | 08:51 AM
TNtech's Avatar
Not hard. I've put a few on actually.
Old Dec 11, 2011 | 12:31 PM
andykb's Avatar
Managed to do it. The wing came off pretty easily. Mast bolted on much easier like this. Jobs a goodun'.
fyrepower
Feb 13, 2020 04:50 PM
afmedic911
Dec 13, 2011 12:32 AM
preed4962
Aug 8, 2007 10:40 PM
afmedic911
Jul 18, 2007 04:09 PM
ramsfantwo
Mar 25, 2006 01:32 PM
