Replacing the Drive/Prop shaft
Old May 16, 2013 | 04:01 PM
jolleyi's Avatar
Default Replacing the Drive/Prop shaft
My Chilton manual has nothing on replacing the driveline, (from the front PTO to the rear diff')
Does anyone out there have a procedure for this with relevant do's and don'ts. I am assuming that i will need to drain off the ATF fluid from the overrun clutch as it looks as though the casing will have to be split. Other than fluid, is anything else likely to fall out. The reason for replacement is that I have a horrible noise coming from the large circular part of the shaft and vibration at take up.
Ian
Old May 16, 2013 | 04:02 PM
jolleyi's Avatar
forgot to add it's a 2000 T & C AWD (of course) LX
Emmans D'Harry
Jul 11, 2015 09:13 PM
StratLou
Apr 13, 2014 10:27 PM
chrysler1
Dec 21, 2013 11:09 AM
Floyd Newport
Dec 7, 2011 07:40 PM
hanoverfist
Aug 10, 2009 07:18 AM
