Replacing starter on a 2002 T&C
Old Feb 26, 2011 | 06:06 PM
HiVoltg30's Avatar
Question Replacing starter on a 2002 T&C
Hi There all...
I'm replacing the starter on my 2002 Town & Country
I'm pretty sure I got both bolts removed at the bell housing, but I cant get the starter to come off.
I noticed on the new starter that there is a pin on the mounting plate, is there a trick to getting the starter off?
Does the old one need to be pried off? if so, is there an easy way to do that? there doesn't seem to be much space to work.
Thanks!
Old Feb 26, 2011 | 09:00 PM
Djinn-n-Tonic's Avatar
...Been there ..done that....
Look carefully and make sure you removed the correct bolts...The upper (Bellhouse side) bolt --15mm...Is quite close to the 18mm bell to block bolt....
If you are sure you have the correct ones removed...A smack with a hammer will sufficiently Jarr it loose.
keheid2003
Feb 28, 2014 11:19 PM
p8ntballnxj
Feb 5, 2012 07:23 PM
Bassim
Jan 3, 2012 02:25 AM
Bassim
Jan 3, 2012 02:22 AM
Petereflynn73
Sep 25, 2011 11:16 AM
