Replacing window regulator system.....
........on my 02 T&C, driver side. Bought the Dorman unit from Amazon, installed it. Everything perfect except that the window is hanging up when it gets to about 1 inch from fully closed.
Don't know, and can't see or feel, what it's hanging up on. As long as I don't raise it above that 1 inch, it works great. Past that it has hung up 2 times requiring me to loosen the track screws at bottom and top, remove the window from the frame connectors, and jiggle/wiggle/finagle the window loose & start over. I'm not sure if the Amazon replacement is correct (the frames are a little different than the OEM...as are the white plastic connectors & clips that hold the window to the frame). But, it all fits perfectly except for the hang-up. Anyone have any familiarity with this? Thanks in advance, Chuck |
