Revs very slow to drop
Old Mar 12, 2011 | 08:52 AM
bingy1972's Avatar
wow, mad they wudnt strip the module, carnt be that much of a job?
well i hope it sorts it am realy intrigued, big bill that, if that sorts it i will be tackling mine myself i think lol.
many thanxs again i can see me doing the same!
Old Mar 12, 2011 | 01:50 PM
dcm1971's Avatar
Collected the car, revs drop faster and runs better, may need an ECU reset.
The pump can be changed (ebay for the pump itself £80), the hardest bit is getting the pump out (drop the tank) and got to change the tank o-ring.
Old Mar 13, 2011 | 06:01 AM
bingy1972's Avatar
ahh great news, at least you seem to have solved the probem, proper pain, will let you know how i get on when i tackel it.
many thanxs for your help, rekon id ave been trying alsorts!
Old Mar 13, 2011 | 05:25 PM
dcm1971's Avatar
hold fire, the old faults are creeping back in...
Hunting at slight throttle in low gears
Revs dropping slower
kinda a pssssssssh noise from the footwell.
Old Mar 13, 2011 | 09:06 PM
  #15
TNtech's Avatar
Originally Posted by dcm1971
as the garage wasn't willing to strip the module to replace the electric pump,
That's good that they didn't. I won't do it either. Those electric motor replacements go bad all too often. Saves you from double labor.
Old Mar 14, 2011 | 02:11 PM
  #16
dcm1971's Avatar
Possible new suspect is the EGR valve.
Old Mar 14, 2011 | 06:39 PM
  #17
bingy1972's Avatar
ohh no, a friend of mine suggested egr valve, anyway of testing it?
Old Mar 15, 2011 | 02:14 AM
  #18
dcm1971's Avatar
Take the pipe from the EGR Valve to the EGR Transducer off, plug the pipe and drive, if fault is gone, EGR valve is sooted up and needs replacing.
Old Mar 15, 2011 | 06:10 AM
  #19
bingy1972's Avatar
many thanx for that will be giving that a go for sure. you are most helpfull will be asking for you number lol
thanks again and good luck!
Old Mar 16, 2011 | 04:45 AM
  #20
glowplug's Avatar
Slow to drop revs can often be a sign of an over lean mixture typically caused by an air leak somewhere. Check all your vacuum pipes e.g. going to the break booster, around the MAF etc. Their may be a hairline crack somewhere ir a jubille clamp that is loose or has slipped off. You can also read the colour of the plugs to see if the car is running lean. A very light brown to white will indicate this. Excessive heat in the exhaust system is alos a sure sign of fuel being overlean. In modern cars it can also be a result of a faulty Lambda sensor that thinks the system is too rich and is telling the ECU to lean out the fuel injection pulses.
