Rough idle 2001 T&C...driving me crazy
Old Oct 21, 2008 | 10:18 PM
bchalker's Avatar
Default Rough idle 2001 T&C...driving me crazy
We are having serious issues with our 2001 Town and Country 3.8L.
Existing problem:
Error code 300 (random misfires). Annoying ride, with audible pops from the plugs, stutter, and hesitation.
What I've done:
Plugs/wires/coil initially changed out. Code still came up...then I switched out the injectors (two actually), since the misfires are occuring on #3 and #5.
After a compression test showing all were at 170-175 psi...
One dealership told me it was two valve springs, and they would fix for $600..."hoping" that would fix it...saying the compressionesentially meant nothing.Another dealership said it was a burnt valve that could be fixed for $1200, and that it was the "first step" to fixing it. I'm a cynic who doesn't trust either of them.
Pep Boys did the compression test, and said they are 95% sure it is NOT internal. The springs and burnt valve diagnosis made no sense to them.
Next thing to check?
I thought the MAP sensor or Throttle Control, but from what I understand, and cylinders would misfire if that was the case...not just 3 and 5. The main CPU control bad? Would I see any other symptoms for that? Is it possible? If not, does anyone have ANY idea of a possible problem? This is really driving me nuts.
Bryan
Old Oct 22, 2008 | 09:52 PM
dodgetech1's Avatar
Default RE: Rough idle 2001 T&C...driving me crazy
would think there would be more codes if the cpu was bad. Are the spark plug wires routed right? I would think that there is either a leak in the intake or in the exhaust or that the timing is off.
Old May 6, 2011 | 06:25 AM
ModdedLHS_2011's Avatar
the car is probably misfiring
marianne
Dec 3, 2009 05:59 PM
serenangel07
Jun 10, 2007 01:25 PM
caravan97
Cirrus & Breeze
May 25, 2007 04:33 PM
dnation
Apr 5, 2007 02:50 AM
OTWOLIMITED
Jan 30, 2007 11:43 PM
