Rust on top of strut
Old Mar 7, 2007 | 06:20 AM
acmectec2001's Avatar
Default Rust on top of strut
I noticed where the strut bolts on is rusted pretty bad. Is it gonna break through? Is there a way to fix it? Any idea what a dealer charges to replace struts?
Old Mar 7, 2007 | 12:38 PM
Default RE: Rust on top of strut
dont worry about it its only rust they wont break its only surface rust anyway. If u had a real rust prob there would be alot more parts that would rust out b4 the top of the struts. DO u live up north where they use salt and stuff or more down south ?
Old Mar 7, 2007 | 02:26 PM
Bernard Feltzer's Avatar
Default x
x
Old Mar 7, 2007 | 04:19 PM
Bernard, Your link didnt work , but I did some searching and there is a TSB on this problem . Chrysler says its cosmetic but from what Ive read from other posters, its more than cosmetic. The TSB number is
23-044-02 . Can you get any info on this Chrysler Tech?
Old Mar 7, 2007 | 07:48 PM
need last 8 of your vin and i will see if hte tsb will even apply to your van or not
Old Mar 7, 2007 | 11:11 PM
ace's Avatar
ace
Yeah the rust thing is a pain dcx has a patch kinda that gets put on to that with a very stron epoxy type stuff. Yeah the vin thing can be done here or call your local dealer and they can check as well probably the body shop thats who deos the work for us.
Oh and i have yet to see one go all the way through yet so.
Old Mar 8, 2007 | 08:04 PM
Old Mar 9, 2007 | 04:47 PM
If the rust is cosmetic, what is the pupose of putting the doubler on top? Couldnt you just sand it off and prime and paint it and then put some wax on it to keep it from happening again? It looks like the doubler was just drilled up and bolted on. Did you put it on yourself or did you have someone else do it?
Old Oct 24, 2007 | 11:29 AM
JusGene's Avatar
Default More strut tower concern..anyone else..
can anyone else chime in on this? Confilcting reports about the tower (hence, strut) "busting through".
I'm not so worriede about the cosmetics. with a '97 there isn't a big concern about my 'baby' being pretty under the hood anymore!
Gene
Old Sep 21, 2020 | 01:59 PM
Adina Homrich's Avatar
Default Very concerned!
Gene
This is the only rust on my 2004 Sebring coupe limited. How does this happen and what can I do??!
