Sliding Power Door Bounces Back !
Old Mar 2, 2011 | 11:47 AM
stewartsoftware's Avatar
Default Sliding Power Door Bounces Back !
I was really pleased with myself today, I got a new wiring track and fitted it and now the power sliding door opens and closes perfectly, but !, a problem it had before (Before I fitted the new wiring track), is that sometimes when closing it would just reverse and open again, and today it did it again, and what’s made it worse is that I thought it had closed and went away and left it for about 30 minutes.
How can I fix it as I though replacing the wiring track would cure all the problems.
Old Apr 13, 2011 | 06:07 PM
alsrag's Avatar
I was told once by a dealer that the T&C has a body computer that needed reprogramming. not sure if I really believe that but I have the same problem with a 2002. Would also like to know if there is a solution.
Old Apr 13, 2011 | 10:05 PM
not the same thing there is a computer for each door and yes there is software updates
Old Apr 15, 2011 | 07:09 PM
knightrider98271's Avatar
Mine does the same thing every now and then, mine has only done it when i am getting into the van after getting my son, it has never done it when i am out of the van. this is a weird issue so far, but until it opens as im walking away im not too worried about it.
Old Nov 26, 2012 | 08:35 PM
bummedagain's Avatar
Default Same problem with door bouncing open
Were you able to fix this problem? I had the wires, track and motor replaced last year and that seemed to fix it for 11 months. It started to act up again, closing to within a few inches and bouncing back open. They replaced the track, wire and motor again, but it did not cure the problem this time!! Getting quite frustrated. Do you have any other solutions?
Old Sep 14, 2022 | 06:27 PM
Tex's Avatar
Tex
Mine does this also.
I notice that when the door closes. There is another motor that kicks in to seal the door.
IF I DO NOT HERE THIS MOTOR. I KNOW THE DOOR WILL COME OPEN AGAIN.
sometimes it may take several attempts to close the door.
Have contacted dealer yet.
Old Sep 21, 2022 | 01:35 PM
Tex's Avatar
Tex
I went to dealer today about the sliding door.
checked everything. Lubricated the door system
they also downloaded an update for the door.
will see if that works.
I asked was this a recall. No it is a minor problem so no recall was sent out.
so check with your dealer.
dakrt360a
Oct 4, 2013 11:32 AM
Huslayer
Jan 28, 2013 10:14 AM
stewartsoftware
Feb 27, 2011 03:54 PM
cajunlady2
Sep 24, 2007 11:18 PM
gregngina
Sep 28, 2006 12:01 PM
