Spark Plugs
Hi There,
I have a 2006 model (Registered Dec 2005) Chrysler Grand Voyager 3.3L V6. I have brought some new Autolite AP5426 spark plus. I have removed NGK Iridium plugs. As you can see from the listing from eBay below, the Autolite ones appear to be correct but......... when I checked them before I bolted the heads back on, they appear to be longer than the Iridium ones to the point where one protrudes, fractionally, below the the head/into the bore. I've replace the head gasket and had the Heads skimmed. "6 x SPARK PLUG PLATINUM AUTOLITE AP5426 - CHRYSLER VOYAGER 3.3L 3.8L 01-07" Anyone else had this issue? Are the Autolite ones good to use? Should I be sticking with the Iridium plugs? Cheers Austin |
NGK for that year is factory dont use autolites only NGK or champion
