Spark Plugs
Old Mar 11, 2019 | 06:59 AM
Haystacks64's Avatar
Default Spark Plugs
Hi There,
I have a 2006 model (Registered Dec 2005) Chrysler Grand Voyager 3.3L V6. I have brought some new Autolite AP5426 spark plus. I have removed NGK Iridium plugs.
As you can see from the listing from eBay below, the Autolite ones appear to be correct but......... when I checked them before I bolted the heads back on, they appear to be longer than the Iridium ones to the point where one protrudes, fractionally, below the the head/into the bore. I've replace the head gasket and had the Heads skimmed.
"6 x SPARK PLUG PLATINUM AUTOLITE AP5426 - CHRYSLER VOYAGER 3.3L 3.8L 01-07"
Anyone else had this issue? Are the Autolite ones good to use? Should I be sticking with the Iridium plugs?
Cheers
Austin
Old Mar 11, 2019 | 09:10 PM
NGK for that year is factory dont use autolites only NGK or champion
keygar
Jan 31, 2019 04:18 AM
purplepuller
Feb 2, 2015 10:24 AM
Speedster1962
Nov 3, 2009 06:23 PM
jquinones
Mar 28, 2008 02:45 AM
dpendley44
Jun 10, 2007 07:53 AM
