stalls when at a stop sign
Old Feb 16, 2013 | 10:41 AM
97 plymouth's Avatar
Default stalls when at a stop sign
hello i have 97 plymouth voyager 3.3 base model
this has never done this befor
but when i stop at a light or a stop sign it stalls out then restarts
i replace idle air control valve and the tps valve
Old Feb 16, 2013 | 11:07 AM
any codes in the computer?
Old Feb 17, 2013 | 03:23 PM
Default Engine Stops.
Yes I would have thought it was the throttle position switch, as if switch not sending voltage to ECU, it thinks engine is stopped.
Resistance check at Switch would confirm that.
Wiring to switch ?
Goggs.
Old Feb 19, 2013 | 08:00 PM
tcbill's Avatar
97, check your battery connections for corrosion. I had a 95 voyager that stalled at lights and stop signs. I took it to a small garage and was told the injectors needed cleaning but he wasn't equiped to clean them. I took it to a place that specialized in fuel injection. Turns out the injectors were fine, the problem was corrosion on negative battery terminal. They cleaned the battery terminals and charged me $5.
Worth a shot.
Bill
cqyAmherst
Jun 25, 2015 10:09 AM
arsace13
Feb 5, 2013 09:58 PM
info_seeker
Nov 17, 2008 11:46 PM
t_bell40
Nov 24, 2007 08:50 AM
Jun 16, 2006 08:08 PM
