strange fuel issues
Old Apr 30, 2017 | 04:22 PM
david49west's Avatar
Default strange fuel issues
Hi Im from the uk and theres not a lot of info here so hope you can help
I have a 2.8 crd 2007 with the erg valve at the front of the engine
The issue I have is , it will only start when you prime the fuel filter
up to a hard pressure
Once this is done the car runs great with no cutting out
I have replaced the filter housing and to my surprise there is no lift
pump in the tank
so im guessing the hp pump does all the work ,
My queston is does the hp pump pull the fuel up and if it does is it the same pump used on the cars with a lift pump in the tank
Could my pump have the sucking side of it down
thanks dave
Old May 1, 2017 | 12:28 PM
Vmaxxer's Avatar
I think I have the same problem I searched my a$$ off trying to find the pump but I found it...
Its in the waterseparator housing next to the tank..
My symptoms: car starting badly after some idle time, otherwise runs and starts perfectly.. Probably due to returnflow fuel through leaks in the pump or something.
Im searching for a new housing right now
Voyager Pilot
Apr 2, 2015 09:07 AM
94grandvoyager
Oct 2, 2014 05:17 AM
jvh24521
Aug 30, 2013 11:16 PM
kdhale21
May 30, 2013 10:36 PM
t15dja
Apr 29, 2013 11:11 AM
