strange fuel issues
Hi Im from the uk and theres not a lot of info here so hope you can help
I have a 2.8 crd 2007 with the erg valve at the front of the engine The issue I have is , it will only start when you prime the fuel filter up to a hard pressure Once this is done the car runs great with no cutting out I have replaced the filter housing and to my surprise there is no lift pump in the tank so im guessing the hp pump does all the work , My queston is does the hp pump pull the fuel up and if it does is it the same pump used on the cars with a lift pump in the tank Could my pump have the sucking side of it down thanks dave |
1 Attachment(s)
I think I have the same problem I searched my a$$ off trying to find the pump but I found it...
Its in the waterseparator housing next to the tank.. My symptoms: car starting badly after some idle time, otherwise runs and starts perfectly.. Probably due to returnflow fuel through leaks in the pump or something. Im searching for a new housing right now |
| All times are GMT -5. The time now is 01:44 AM. |
