Town & Country 2001: No heat in front
Old Dec 22, 2007 | 11:56 PM
finlandmauri's Avatar
Default Town & Country 2001: No heat in front
Hi,
I am a new owner of a 2001 T&C with automatic temperature control. I am experiencing an issue with the heating system as follows:
- no matter what degree I select, it blows only cold air in the front; the rear does get warm/hot air in the meantime. Issue only exists for the front.
Any help/input would greatly appreciated! Thank you!!!
Old Dec 23, 2007 | 04:32 PM
Default RE: Town & Country 2001: No heat in front
coolant level low
Old Dec 23, 2007 | 05:46 PM
Hi Chrysler Tech,
Thank you for your quick reply. I filled the coolant level back to the max, but it still doesn't blow hot air. Do you have any other ideas?
Thanks.
Old Dec 23, 2007 | 11:46 PM
did u just look in the over flow or did u look in the radiator itself as well?
Old Dec 24, 2007 | 12:27 PM
I assume the overflow (the little plastic container that shows the Min and Max levels) only. How would I check the radiator itself? Thanks again!!
Old Dec 24, 2007 | 05:01 PM
open up the cap thats on the radiator left side push down and twist to the left.
Old Dec 24, 2007 | 08:46 PM
Ok, thanks. Radiator is full as well. Still not working. Could it be an electrical problem, since it sat for 7 months on a lot before I bought it this past weekend...
Old Dec 24, 2007 | 11:17 PM
if u can locate the motors on the driver side under the dash look for the one that will move when u trurn the air temp the others ones would be for air direction.
Old Dec 26, 2007 | 10:13 AM
motor for temp is working. when chaning temperatures the "lower" motor is engaging. (still only cold air blowing.)
Old Dec 26, 2007 | 01:51 PM
then u have a clogged heater core then feel the lines that go into the fire wal if one is colder then the other it is clogged up.
