Town & Country Heater Hoses
One of the heater hoses on my 2000 T&C I believe has come loose as it ineffectively blows enough hot air into the van. I was just wondering if anyone knew where the heater module and hoses where located so I could check it out.
are you refering to the ducting or something else what do you mean.
are you not getting the air hot enough or is it the speed of the air thats bad
most of that stuff is under the dash on the passanger side i think.
kinda stumped on this one
does it have rear air?
is the air hot ? or just the lack of well i guess pressure coming out?
i am gonna try and help ya i just need a bit more info
well it blows out hot air after like 20 minutes or so. Like the air starts off like its just blowin in air from the outside but then it gets semi-warm notin like hot even though i crank up the heater. the air seems to blow out fine like full power when you have it on the highest setting it just blows somewhat warm air at the normal rate for that setting. i think when the van got the frontend foxed teh mechanic left one of the hoses off but i wasnt sure but ive been lookin under the hood for the hoses but i just cant seem to find the ones for the heatin unit
ok now i get it
have you checked the t-stat
the hoses which you are talking about either have coolant in them
does the temp gage go up to the half way point at all
i think this is a t-stat or radiator problem but i could be wrong i am not a tech i just hear them talk about all the problems they have and how they fix'em
milesy_boy
Oct 8, 2009 05:54 PM
bbenajmi
Jun 18, 2009 09:01 AM
