transmission fluid for manual voyager 2003 CRDI 2.5
dear Gents!
can you please advise what specs of transmission oil MUST GO into manual transmission in CHRYSLER VOYAGER, 2003, 2.5 CRDI, vin 1C8GYN3713Y547084 ) as my first and third gear keep slipping out (without any noise) so I am hoping that there is a problem with the oil quality cheers! PLEASE HELP!!! Bojan from Balkans |
Edit: sorry misread your post, i thought you where talking about auto transmission. I dont know if there is any different oil for manual transmission?
The manual gearbox uses ATF+4 fluid, A fluid change won't do any harm but I'd surprised if it helps.
Regards Richard |
Found a very good post from übersarcastic :D user "Glowplug"
https://www.chryslerforum.com/forum/...d-10820/page4/ |
slipping out from first and thirs
dear guys, does anybody absolutely anybody has any idea why my gears are slipping?
I disconnected cables and reached gearbox from under the hood and still slipping + changed oils 4 times in last 3 months + refurbished front engine mount + opened gearbox and inside looks great. any idea? PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! |
Just wondering if your cables are stretched and lever in gearbox is not being pulled enough to engage slides/mechanism on detent balls. But you say you have engaged it manually under hood and its still the same. You say you opened gearbox, did you find any loose nuts on end of shafts. The Renault scenic engine jumps out of 5th gear when gears end nut comes loose or falls off.
If all else fails its a Gearbox out job...Try second hand. |
Originally Posted by goggs
(Post 82473)
If all else fails its a Gearbox out job...Try second hand. Regards Richard |
