Transmission light on after battery change
Hi guys, just fitted a new battery in my 2002 2.5CRD voyager, took it out for a quick spin and the engine management light came on and the car also went into limp mode, stop for a few mins and the light was still on but it was driving normal. Had the bonnet open whilst I was changing the battery and it was raining pretty heavy any chance a bit of water could be the culprit ?
Cheers |
try doing the key dance to see what fault codes are logged.
Regards Richard |
Originally Posted by tfb
(Post 76938)
Regards Richard |
yep, thats it
(Post 76948)
yep, thats it
P0100 is the Mass Air Flow sensor.
Time to get a multi meter out and check some of the voltages. It will report a fault if the reference voltage is below 4.8 or 5.2V (but most likely other items would report faults if that was the case) It will report a fault if the sensor voltage is less than 0.2V or above 4.5V It will also report a fault if the sensor voltage does not match what it expects given the current engine load, this can be the hardest to diagnose as it may not be the MAF, eg an air leak in the intake system can cause this. I'll ulpoad the MAF connector details later Regards Richard |
Maf
(Post 76952)
MAF connector is here
https://skydrive.live.com/redir?resi...nt=file%2c.pdf and yes, it would cause it to go into limp mode Regards Richard |
