UK: 2000 2.5td Grand Voyager Idler Pulley
Old Jul 13, 2011 | 05:40 AM
sjbilton's Avatar
Default UK: 2000 2.5td Grand Voyager Idler Pulley
I had to replace the water pump so ordered replacement idler pulleys as well. The main dealer parts department said that there were two identical pulleys - so I ordered them.
It turns out there are three, but the third isn't part of the "Cooling system" - so it didn't come up on their parts computer in that area.
I now have the third pulley, but unlike the other two this one doesn't just bolt onto the side of the block, but sits inside a cradle between the powersteering pump and the crank pulley.
I've got the service manual from the ?russian? website but can't find where this third pulley is covered? The cradle appears to be mounted to the block but it appears to go behind the timing chain covers.
Can anyone tell me how to change this pulley - or what system it might fall under in the service manual - I've looked under steering, cooling, alternator, etc and can't find any mention of it.
Thanks in advance
Steve
Old Jul 13, 2011 | 01:47 PM
booke23's Avatar
Is it the tensioner, or high pressure fuel pump pulley?
Old Jul 14, 2011 | 04:01 AM
sjbilton's Avatar
It's the lower of the three pulleys identified as "3 - Idler Pulleys" on this diagram.
between the Power Steering Pump Pulley and the Crankshaft Pulley.
Old Jan 7, 2021 | 07:25 AM
iztokd6's Avatar
Please, from what book is the picture pulleys.jpg?
Old Jan 7, 2021 | 07:27 AM
iztokd6's Avatar
What is the size of the bigger of the 3 pulleys? Is its diameter 85 mm? The small ones' is 70 mm.
Dtdp95
Aug 23, 2020 05:03 PM
fmendez65
Nov 20, 2014 08:36 AM
estrika
14
Mar 29, 2014 08:53 AM
green2000tc
Sep 30, 2010 02:40 PM
fmmike
Cirrus & Breeze
May 3, 2010 09:37 AM
