uneven wear on Rear Tyres
Old May 26, 2013 | 11:53 AM
TomC's Avatar
Question uneven wear on Rear Tyres
Hi Guys
I have a UK 2001 Grand Voyager 2.5 crd and i have noticed that the rear tyre are wearing unevenly scrubbing the outside edge on the rear N/S and the inside edge on the Rear O/S.
At first i thought it was the wheel bearing as the rear N/S is the worst but having jacked it up to check for wheel wobble. There was none and the rear shockers appeared to be ok. I therefore wondered if anyone has any idea what the problem is
Old May 27, 2013 | 03:58 PM
Hi, this is an indication that the size between the front wheel centre and back wheel centre is smaller on nearside compared to offside. Your car must be crabbing slightly but not noticeably along the road. Try measuring the nearside centres against offside centres to see what you get first.
Past accident damage to front subframe or rear spring mounts methinks. You've a cart rear axle so wheels parallel.
Unless your cars got independent rear suspension.
Give it a good going over underneath for damage.
Goggs.
jkersh1
Jan 30, 2014 06:15 PM
Gil
Dec 8, 2013 08:54 AM
nutinph
Feb 12, 2011 06:11 PM
jjmohan
Dec 6, 2007 08:04 AM
cmr1194
Nov 13, 2006 03:52 AM
