voyager 2.8d electrical probs
Old Sep 23, 2010 | 05:25 AM
  #21
mathiaskt's Avatar
Originally Posted by Merlin
Hi
Yes it's a dealer battery part number that I fit to my customers cars with this issue. It is a lower rating the the red top battery but my customers never have any issues again. You do have to cut the battery tray to make it fit but just the front lip. The charger looks good and is almost the same as the dealer uses.
Ah I see - thanks. Will see how the changer performs first. Also that battery part number is almost not existent on the google search. Is there a place that part number can be bought from?
Mathias,
Old Sep 24, 2010 | 06:04 AM
  #22
mathiaskt's Avatar
Guys,
The battery let me down this morning again. I hope to receive the charger today or tomorrow. Someone told me Chrysler cars do have a pretty poor memory - not quite sure what it really means though. Since I intend to remove the battery out of the car and charge it for a few days at home before putting it back, I am not sure if this would cause any problem. Also I am assuming that I would still be able to lock/unlock the car manually without the battery in.
Thanks,
Mathias
Old Sep 26, 2010 | 04:06 PM
  #23
Merlin's Avatar
The battery I posted above is a Chrysler battery you get from the dealer. other then the radio code you should be fine.
Old Sep 27, 2010 | 04:15 AM
  #24
scaryspider's Avatar
Thumbs up Battery Problem Update
Hi
Just to update everyone 2 years on, Car still going strong no more battery problems after fitting VARTA Silver Dynamic type E44 which is 12Volt 77ah 780 amp as previously posted and attached to a CTEK MULTI XS3600 once a year to maintained in the winter.
Regards
Peter
Old Sep 29, 2010 | 05:29 AM
  #25
mathiaskt's Avatar
Originally Posted by scaryspider
Hi
Regards
Peter
Many thanks for the update. I will be considering that after the full charge. Received the charger yesterday. Took the battery out of the car and charge it all night. It now says it is fully charged. I have left it on the charger but will put it back in the car tonight.
Mathias,
Old Oct 1, 2010 | 05:21 AM
  #26
mathiaskt's Avatar
Did put the battery back in the car yesterday. It works for now. Voltage was 12.80 when I put it in the car. If it goes flat again I will just replace it.
Note that with the battery out and the car locked, I couldn't use the key to manually open the driver door or any other door except for the back door or the boot. Got in the car from the boot and manually opened the driver door. All is fine now.
Mathias,
Old Oct 25, 2010 | 11:34 AM
  #27
frenchy62's Avatar
Default battery problem crysler voyager 2.8l crd bva
hello Scaryspider,
sorry but i'm french. excuses for my bad english.
i try to translate your forum abaout "battery problems" . it's not very simple cause' it's not writen in good english but i think i understand.
i think my problem is as similar as your's. in the enter of winter, when it's cold outside, i have great difficulties to make the motor on. like you, all the needles turns to the right before comin to zero and before the lights come on. sometimes i've not enough battery to make the motor on and i've to take charge on an other car with cables. i've change the battery but it's egal it's make the same thing. not all the time but oftenly. it's began two years ago when my son come to play pushing the button opening the lateral back door twenty times when the car was parked.
since this time, i show my car to the garage bout they don't find anything wrong. i've change the battery but perhaps not too strong as your's ??
do you thing i've to take a battery like you or do you thing it's somthing else?
thank's a lot to speak good english
bye
Old Oct 25, 2010 | 06:01 PM
  #28
frenchy62's Avatar
Default answer
Hi
Regards
Peter
hello,
i forgot to say you what is my car:
van CHRYSLER VOYAGER 2.8L CRD BVA WITH VIDEO
i say "with video" cause' a garage chrysler says to me that he has allready have the same problem on the same car cause of a problem with the dvd video !!! ????????
FRENCHY62
Old Nov 6, 2010 | 07:12 AM
  #29
frenchy62's Avatar
hello Scaryspider,
bye.
frenchy62
Old Nov 6, 2010 | 07:13 AM
  #30
frenchy62's Avatar
hello,
FRENCHY62
