voyager 2004 2.4l manual hand brake adjustment
Old Aug 28, 2013 | 12:20 PM
CP35's Avatar
Default voyager 2004 2.4l manual hand brake adjustment
Does anybody know if you can adjust the hand brake on a 2004 voyager, 2.4l manual.
Old Aug 31, 2013 | 06:22 AM
antalo's Avatar
All "hand brakes" are adjustable. Follow the cable under the car. There should be an adjuster before it splits up going to the rear wheels. It may be covered with undercoating and may be pretty rusty. Read other posting in this section. You need to take the rear tires off and check if the adjuster is moving. It also may be rusted if not used regularly. It should spread the braking surface to the drum to work.
Old Sep 4, 2013 | 12:17 PM
CP35's Avatar
Default cp35
thanks for the info, I read some other posts and they talk of an adjuster under the hand brake lever. Does this apply to this model as well, I can't get under a car unless I go to a garage who will obviously charge me for it.
Old Sep 4, 2013 | 12:29 PM
Breaking300's Avatar
Are you talking about the control? This part ---->
PARKING BRAKE CONTROL for 2003 Chrysler Voyager|4683277AE
Old Sep 5, 2013 | 09:32 AM
CP35's Avatar
I don't know what a control is, there was no picture in your link.
On other posts they mention a plastic clip fitted to the hand brake lever, I believe it was a part of the recall for the hand brake.
nitro_warrior
21
Jul 17, 2015 09:37 AM
silentdub
Apr 24, 2015 08:27 PM
Dean11
Sep 29, 2009 10:56 AM
bassy
Apr 2, 2009 03:00 PM
flox45
Oct 11, 2007 03:07 PM
