voyager 2007 ABS & central locking
Old Sep 30, 2014 | 12:33 AM
nskeates's Avatar
Default voyager 2007 ABS & central locking
I have a 2.8CRD and the ABS light started coming on and off over a period, it is now on constantly. had the codes read and said ABS sensor left and right error and internal error with ABS module. Is this my module failing ? If so where can it be located ? Are there any known problems with the module ?
Also a while back my battery went flat, this is all sorted now but since then my drivers rear sliding door will not lock/unlock with the fob. Have removed the IOD fuse but makes no difference. I cannot hear the soleniod working on that door. Is there anything i can do or look for to sort this out ?
any help appreciated.
thanks
Old Sep 30, 2014 | 01:49 AM
TimmyTim's Avatar
My ABS light has been doing the same thing! Most prob cause is dirt/rust on the pick up ABS ring!Butit doesn't bother me tbh!... Get a wire brush on it to clean it up and it will solve it...
Old Sep 30, 2014 | 02:39 AM
nskeates's Avatar
thanks will give that a go.
jp2417
Jul 15, 2017 01:39 PM
Gavin
Mar 10, 2012 04:39 AM
mjtray
Mar 7, 2012 04:01 PM
ashnatlucy
Oct 21, 2011 03:32 PM
romualdo
Jun 4, 2010 07:04 PM
