Voyager not starting
Old Nov 1, 2009 | 09:39 AM
gina2201's Avatar
Default Voyager not starting
I have a 2003 Voyager 2.5 Diesel, only had the car approx 6 weeks.
Initially car was fine until a few weeks ago it has not started and has to be jump started and then it will be fine for a while but has not started now 3 times, each time jumping the car has sorted it (albeit temporarily)
My initial thought was the battery, however not knowing much about Chryslers is there anything else I can check first before forking out on a new battery?
Thanks all.
Old Nov 2, 2009 | 03:57 PM
Merlin's Avatar
get the battery tested would be the best start not just replace it. If it passes you would need to do a battery drain test and charging test. come back with the results if you need more help.
If you only do short trips you don't want a red top (Gell) battery but a lead acid battery instead.
staM
13
Jun 20, 2014 12:36 PM
Decasme
Oct 13, 2011 11:14 AM
mathiaskt
Apr 17, 2010 04:47 AM
G Man
Apr 7, 2009 03:24 AM
sharico
Dec 9, 2006 04:14 AM
