Water Leaking frm Frnt Evaporator compartment
Old Nov 5, 2012 | 01:53 AM
Huggy59's Avatar
Default Water Leaking frm Frnt Evaporator compartment
To all d experts out there. I'm using Chrysler Grnd Voyager yr 2000, 3.3L.I need an advise as to what shud I do to solve d abovesaid problem.
I've removed the glove compartment as awell as the passenger carpet and I cud see clean water dripping quite heavily ince I 'ON' the a/cond.
Pls advice as what cud be the problem.
I honestly hope n wished that there's only some dirt got stuck to d water outlet.
Waiting fr yr advice members.
Tqvm.
Old Nov 5, 2012 | 03:13 PM
Raptor 07's Avatar
A plugged A/C evaporator condensate drain is the usual cause for wet carpets on the passenger side. Look down behind the alternator at the firewall. You should see about a half inch diameter tube sticking out from the firewall. If it's had the TSB completed it may be a 90 elbow. Take a piece of wire and carefully ream out the tube. You don't want to get too frisky and damage the evaporator.
Old Nov 6, 2012 | 02:28 AM
Huggy59's Avatar
Tqvm bro,I will try to locate d plug n do as per yr advice.
Old Jun 17, 2014 | 04:24 PM
roythebus's Avatar
Default VBoyager 2005 2.8TDi carpet wet
My Voyager suffers from a wet carpet on the passenger side when the air con is being used. It seems to take days to dry out. It's been to the local garage 3 times and each time they reckon they've fixed it. Last time they changed to condenser as that leaked all the gas out, but now we use the aircon again, the carpet's still wet. Any ideas or is it the same as the above answer?
Old Jun 18, 2014 | 07:02 AM
Huggy59's Avatar
Dear Raptor 07,
I faced d same problem sometime ago. In my case,it was a clogged drain pipe at the firewall in the engine compartment.
Pls locate the drain pipe and while the a/cond is on pls observe whther theres water flow out frm the drain pipe,if theres none,try to run a small rod, nail or anything that could go thru the pipe n run it in n out.
Once its clear than evrtg shud ve ok.
Old Jun 29, 2014 | 12:00 PM
roythebus's Avatar
This is a right hand drive car. The car's been to the local garage 5 times now. Last week they unblocked the drain but this week we've soaked up about 2 gallons of water from the passenger side foot well!! Water seems to drip from the drain (what looks like a 1/4" pipe) onto the left side chassis rail, then finds it was into the carpet. There's also a small amount goes onto the road. Maybe there's another drain pipe to unblock? Should the water drain onto the chassis?
Huggy59
Oct 6, 2011 10:13 AM
winkster01
Oct 2, 2010 07:10 PM
telaskowski
Jun 12, 2010 06:32 AM
helpmysebring
Jul 7, 2009 12:47 PM
Brokenass
Jan 31, 2007 05:09 PM
