Wespasto preheater fuse
Hi,
Does anyone know which fuse or relay is for the preheater. Chrysler voyager 2007 2.8 CRD Thank you |
See here
You are more than 14 full of fuel ? Q&D is get underneath and unplug the Thermotop/run the engine/turn engine off/re-plug the Thermotop and the unit will re-boot its logic. Best of luck.
14 full - should read 1/4 full.
Reply to preheater
Originally Posted by QinteQ
(Post 104183)
Thanks for the reply. I want to disable it, it is working perfectly fine. The issue I have is that the stat is stuck open and the preheater is constantly on. Until I fixed the stat (seperate thread) I want to disable the preheater. |
Uses very little fuel 10 minutes and £10 to do the stat, just do the stat M8
(Post 104189)
