Wespasto preheater fuse
Old Jan 31, 2018 | 02:54 PM
yableep's Avatar
Default Wespasto preheater fuse
Hi,
Does anyone know which fuse or relay is for the preheater.
Chrysler voyager 2007 2.8 CRD
Thank you
Old Feb 1, 2018 | 10:28 AM
See here
Old Feb 1, 2018 | 10:32 AM
You are more than 14 full of fuel ? Q&D is get underneath and unplug the Thermotop/run the engine/turn engine off/re-plug the Thermotop and the unit will re-boot its logic. Best of luck.
14 full - should read 1/4 full.
Old Feb 1, 2018 | 10:35 AM
yableep's Avatar
Default Reply to preheater
Hi Qinteq,
Thanks for the reply.
I want to disable it, it is working perfectly fine.
The issue I have is that the stat is stuck open and the preheater is constantly on. Until I fixed the stat (seperate thread) I want to disable the preheater.
Old Feb 1, 2018 | 02:15 PM
Uses very little fuel 10 minutes and £10 to do the stat, just do the stat M8
Old Feb 1, 2018 | 02:44 PM
yableep's Avatar
Default Thanks
Thank you
bubba0019
May 23, 2016 10:19 AM
dieselvoyager
Feb 6, 2016 07:35 AM
acat29
Other
Mar 1, 2013 11:16 PM
lindap
Dec 9, 2006 04:31 AM
v1rott
May 8, 2006 08:23 PM
