What does the IPM unit do on a 2005 CGV
Morning
Can anyone tell me what the Inteligent Power Module (IPM) on the above does on the car? is this an interface between the various electronic components around the vehicle and the Main Instrument Cluster (MIC) and the diagnostic plug on board?
DESCRIPTION
The Integrated Power Module (IPM) is a combination of the Power Distribution Center (PDC) and the Front Control Module (FCM). The IPM is located in the engine compartment, next to the battery.(INTEGRATED POWER MODULE). The PDC mates directly with the FCM to form the IPM. The PDC is a printed circuit board based module that contains fuses and relays, while the FCM contains the electronics controlling the IPM and other functions. This IPM connects directly to the battery positive through a four pin connector. The ground connection is through two other connectors. The IPM provides the primary means of voltage distribution and protection for the entire vehicle.
OPERATION
All of the current from the battery and the generator output enters the Integrated Power Module (IPM) through a four- pin connector on the bottom of the module. Internal connections of all of the power distribution center circuits is accomplished by a combination of bus bars and a printed circuit board
OPERATION
Going on from the above would I be right in thinking that this would act as an interface between the ABS module and the Main Instrument Cluster with the ABS indicator and the diagnostic plug?
OK So what would prevent the ABS light coming on when you first put the ignition key in? the engine starts as normal then the abs light will come on along with the park light? the ABS CAB module has been replaced and all the local wiring to the CAB module checked?
The problem is that the Chrysler dealship cannot communicate with the ABS unit so they cannot read the codes? I did trace the PCI bus line from the ABS module back to the IPM unit and the block diagram indicates that the diagnostic plug is connected at the other end to the IPM unit, continuity of the cables are good and so this is why I was asking if the IPM was defective?
Addis
Dec 7, 2014 09:11 AM
SpudlerT+CTouring
Aug 3, 2014 06:18 AM
neato0z
Jan 17, 2010 07:17 PM
