what is trick to installing new window regulator on 03 T&C?
Old Feb 17, 2011 | 11:25 AM
rastoma's Avatar
Default what is trick to installing new window regulator on 03 T&C?
I just replaced the driver side window regulator and motor but I know I did it in an 'unapproved' way
I removed the speaker in the door and still could not figure any way to get both sides of the regulator inside the door.
I removed 3 screws that held the spool for the wire cable and that gave me a few extra inches to play with. Once both sides were inside the door I just replaced the spool back on the side of the motor. I'm sure that's not the proper procedure but it worked.
I have no doubt I'll be replacing the passenger side one of these days and just wondering if anyone has any tips or possibly pictures taken while doing a replacement.
Old Feb 17, 2011 | 06:13 PM
Djinn-n-Tonic's Avatar
....2 things...
1...remove the glass from the door FIRST
and second....cut the tie strap and replace it when youre done....
Old Feb 17, 2011 | 06:37 PM
rastoma's Avatar
Originally Posted by Djinn-n-Tonic
....2 things...
AaaHaaa!!! I knew it.
So cut the tie strap that has a tag on it that says: "DO NOT CUT".
Too bad I wasn't smart enough to think about replacing the strap afterwards LOL!
Barbara 2
Aug 8, 2010 08:34 PM
minokaah
May 5, 2009 04:18 PM
garyw
Apr 17, 2009 07:19 PM
TrickyTree
Aug 31, 2008 05:09 AM
TrickyTree
Aug 31, 2008 05:00 AM
