where is the spare wheel on stow n go 2005
Old Mar 27, 2013 | 02:57 AM
Jason1969's Avatar
Default where is the spare wheel on stow n go 2005
Hi I hope some one can help me,
I have got a 2005 Chrysler Grand Voyager stow n go, does it have a spare wheel? if yes where is it and how do you get to it?
my old CGV had it at the back under the boot, but not there on my stow n go!
Thanks for all of you help
Jason
Old Mar 27, 2013 | 03:19 AM
travelmad's Avatar
For vehicles equipped with fold-in-floor seating, the
spare tire is stowed inside a protective cover located
under the center of the vehicle by means of a cable winch
mechanism. The
spare tire drivenut is located on the
floor, under a plastic cap between the front seats.
The tool pouch contains three pieces and can be assembled
into a Spare Tire Hook to remove the compact
spare tire/cover assembly from under the vehicle or a
Winch
THandle to raise/lower the compact spare
tire/cover assembly.
Old Mar 27, 2013 | 03:21 AM
rodger's Avatar
Its probably underneath the vehicle between the front seats. Its a spacesaver wheel. You lower it down from inside the car. In the boot left hand side there should be the tool to lower it. Its like a T bar with an extension.
Remove the small rubber mat in the console between the front seats and thats where the nut is that lowers the wheel.
I think there was a recall on the mechansim that lowers the wheel, you might want to check with a dealer to see if it has been done.
Old Mar 27, 2013 | 07:11 AM
Jason1969's Avatar
Thank you for your help, I hope I don't ever have to use it, as being in a wheelchair I have no way of getting it from under the car after I have dropped it down.
Thanks Jason
Old Mar 27, 2013 | 12:01 PM
Hodges710's Avatar
you should be ok, ive seen a video of a person in a wheelchair using it with no problems, just have to bend over a little. Your tool for dropping the tire also has a hook type deal to reach the tire to pull it out.
Alan mills
May 20, 2013 10:32 AM
Contact
Feb 10, 2013 07:52 PM
goggs
Nov 16, 2012 02:51 PM
GrahamLemon
Apr 11, 2011 02:26 PM
Feb 3, 2005 11:48 PM
