window only goes down
My driver side (2008) window will only do down when the switch is pushed. It will not return up. I've checked the window motor and it's good. Could it be the switch has gone bad? You can put the window about half way down and stop. If you try to put the window back up by pulling up on switch it just continues to go down. So once all the way down you cant get it back up. Help please.
In my experience with a window only going partially up by switch, the problem was the window regulator going bad.
After lowering the window, while holding the switch in the up position, try thumping the centre area of the door card. If the carbon brushes are sticking the window will go back up. Sticking brushes in the drivers side is a common problem with the Voyager/T&C.
