window only goes down
Old Jan 27, 2018 | 11:46 AM
HarleyRob's Avatar
Default window only goes down
My driver side (2008) window will only do down when the switch is pushed. It will not return up. I've checked the window motor and it's good. Could it be the switch has gone bad? You can put the window about half way down and stop. If you try to put the window back up by pulling up on switch it just continues to go down. So once all the way down you cant get it back up. Help please.
Old Feb 27, 2018 | 01:42 PM
TurboRev's Avatar
In my experience with a window only going partially up by switch, the problem was the window regulator going bad.
Old Feb 28, 2018 | 12:44 PM
After lowering the window, while holding the switch in the up position, try thumping the centre area of the door card. If the carbon brushes are sticking the window will go back up. Sticking brushes in the drivers side is a common problem with the Voyager/T&C.
Aug 1, 2016 05:45 PM
Chrysler Forum Editor
Jan 11, 2013 08:04 PM
carsoftampabay
Cirrus & Breeze
Oct 26, 2012 11:31 PM
miki75
Mar 29, 2010 01:45 PM
davet
Aug 11, 2007 04:17 PM
